I want to find pages which includes certain property.
for example, I have property “x1” “x2” “x3”
and I want to query for all pages with a property including “x”
Thanks!
Thanks!
There are several functions you can use to query for page properties:
This searches for a page with type:: paper
in the meta-data:
{:title [:b "Paper properties"]
:query [:find (pull ?p [*])
[?p :block/properties ?prop] ; save properties of page ?p to ?prop
[(get ?prop :type) ?t] ; of all the properties in ?prop, get :type save to ?t
[(str ?t) ?t2] ; convert ?t to string ?t2 (important!)
;;you can use either of these, or a combination:
;[(= "paper" ?t2)] ; ?t2 equals "paper"
;[(clojure.string/ends-with? ?t "aper")]
;[(clojure.string/starts-with? ?t2 "pap")]
;[(clojure.string/includes? ?t "ape")]
Comments start with ;
just uncomment the parts you want to use
It’s very clear and inspiring.
I want to find all the “blocks with certain prpoerty”.
For example, each paper takes a page; in the page, some blocks has certain block-property.
And I want to write some code at the beginning of each page, to display all the blocks with block-properties, so that I can recall what this paper is about with a galance.
Thank you for you time! and I understand this will be very complex and might not be achieveable. Thank you all the same~
