I am trying to have text after using a heading to be normal sized text without starting a new line. eg. ## Heading. Then regular sized text. Can’t figure out how to do that.
you can use embed html
@@html: <h2 style="display:inline">heading</h2><span> and normal </span>@@
this will display as
as far as I know, there is no way doing this in markdown without writing html
Thanks for the taking the time to reply. Maybe i will have to change what I’m trying to do.
The reason I wanted to do that is because when I refer to a block reference that has a heading and then normal text which is started on the next line, the block reference only shows the heading and not the following text. The text was put on another line obviously so the heading wouldn’t make the text the same size as the heading. I want to see the heading AND the text on the next line in the reference. Is there a way to do that without using a block embed?
Wanted to help but I have no knowledge about this, sorry.
