Hi, I copy pasted a query from here: https://mschmidtkorth.github.io/logseq-msk-docs/#/page/Queries%2FAdvanced%20Queries%2FTutorial
And setup example data to test it.
This is the query I copied:
{:title "Find: MyTag and MyOtherTag"
[?b :block/marker ?marker]
[(contains? #{"TODO" "DOING"} ?marker)]
[?b :block/ref-pages ?p]
[?p :block/name ?tag]
[(contains? #{"mytag" "myothertag"} ?tag)]]
Screenshot from my logseq, with both the query, and the test data that I expected it to return.
Thank you - that really helped - in the sense that it motivated me to continue trying…
but in all honesty: thanks!
Moving it to a clean graph to not fix it (with all plugins and other customisations turned off).
However, I managed to fix it, I do NOT now understand HOW:
This is what fixed it: lower-case letters only within the tags I am searching for:
I do not now understand how this 'accidentally happened.
When I posted the code here, it changed the tags to lowercase - check my screenshot above, where the tags are camel-backed. So when mentaloid copied it from here it worked, as it did for me this morning.
This shouldn’t be the cause of the issue - the documentation here (https://mschmidtkorth.github.io/logseq-msk-docs/#/page/Queries%2FAdvanced%20Queries%2FTutorial) use capital letters…
Summary
It doesn’t?
Either way, the attribute :block/name is always in lower case.
Also :ref-pages is deprecated. Should use either :path-refs or :refs.
Where :path-refs takes ancestors into account:
:path-refs will return the block TODO block without a tag. :refs will not as it only looks at the references present directly in the block itself.
