Bellut points are nice but I don’t want to have a bullet point in front of every paragraph. Is there a setting that I am missing ?
much thanks
much thanks
You can use the command t d.
Thanks for the solution. It worked great for the logseq app interface (on Mac) , but when I export the graph to publish on web, the bullet marks are still carried on … Is there a way to totally remove bullets ?
Maybe you can select the element and change the default CSS rule in the corresponding file.
Thanks @Didac - I can handle css but I am pretty new to [[logseq]] , wondering if you could point me to the file and element name …
https://docs.logseq.com/#/page/publishing
style.css
.bullet-container .bullet {
#background-color:var(--ls-block-bullet-color,#394b59);
Comment out that second line
The logseq plugin logseq-plugin-doc can help with this.
Will it retain the looks if I exported entire graph for web publishing ?
I think it would if you did the export one page at a time, but it doesn’t seem to have a convenient way to call it for exports of an entire graph.
https://docs.logseq.com/#/page/6387ea4d-366e-4208-bad9-a1e464ea9553
You can workaround this with this example custom.css
// This uses the logseq-dev-theme but the url can be changed to any theme's github url
@import url("https://cdn.jsdelivr.net/gh/pengx17/logseq-dev-theme@main/custom.css");
On the same lines , I figured that custom css from https://demo.diasporamemory.com/#/page/Diasporic%20Memory works well too .
Hi all! I found this thread on Google while looking for something else, and wanted to chime in, as the author of the above link. ![]()
I created a separate export.css file to hide the bullets (and other gunk). export.css is great for styling that’s specific to your exported graph static site.
Here’s mine: https://github.com/Digitized-Diasporic-Memory/Memory-Graph/blob/main/static/css/export.css
