Hi, I would like to achieve a hierarchical tag system. For example, I have a page and would like to tag this page as
data augmentation
text data augmentation
But the second tag is a subtag of the first tag.
Ideally I can only tag the page as text data augmentation, and the logseq can infer that this page is also linked to data augmentation (supertag). But currently if I only tag text data augmentation, then it wouldn’t link the page to the first tag data augmentation. Thus I am wondering if there is an easier and better way to achieve something like this. Thanks!
I think what you may need is namespaces… use a forward slash #[[heirarchy/level1/level2]]
Thanks! Now I can see the tag in the page of hierarchy. I am wondering what is the best workflow? Should we later only work on hierarchy/level1 instead of level1 page? Since level1 is, in the eye of logseq, not the same as hierarchy/level1.
#[[hierarchy/level1/level2/level3]] is not equal to nested tag. For instance, when I need to find tag[[hierarchy]], logseq only links the tag[[hierarchy]], not include tag[[hierarchy/level1]], tag[[hierarchy/level1/level2]] and tag[[hierarchy/level1/level2/level3]], that is what I want.
Where can I find info about this in the logseq docs? I’ve searched high and low and can find no docs on this tags/hierarchy/thingy!
