It’s not possible to hook into this modal unless you want to manipulate the DOM directly which is not ideal. Having a separate right click option would be the best.
I’d recommend looking at the PDF export plugin’s code as I’ve parsed the entire contents of the page.
Also on a separate note, I’m curious about what you mean by a hassle navigating the docs, could you give some specific emaples and points of improvements. I’m working on improving those atm.
And very few methods seem to be described. The types and names are helpful, but apart from that its guesswork to figure out what they do.
Don’t get me wrong, I am HUGELY fond of the project and what you have built in such a short time is amazing.
But these particular API docs could use a little more description
