it would be possible to select with customizable hotkeys?
I also support this, this would make my workflow much easier
I agree - this would make my workflow a bit smoother.
This would be nice. It would also be nice to add template names to the / dropdown
This would make workflow much easier and less friction.
totally agree, would help a lot!
- Agree that it would be ideal to have the option as standard
- In the meantime, custom keyboard shortcuts can be created with javascript
- Or a plugin can be used, such as Full House Templates (GitHub) by @stdword
- by default
ctrl + twill open a template selector - has many other powerful options with templates
- documentation is not comprehensive nor current
- by default
