I am sorry if I missed info about this. I want to jump to the top card in the right sidebar Content’s Tab. Is there a way to do it with keyboard? So far Tab isn’t helping to navigate through the UI elements to reach that spot but I would rather have an even more straight forward shortcut.
Here is a first custom.js step:
document.addEventListener("keydown", (e)=>{
if (e.ctrlKey && e.altKey && e.key === "c") {
const span = document.querySelector(".sidebar-item")?.querySelector("span.inline")
if (!span) return
span.dispatchEvent(new MouseEvent("mousedown", {
bubbles: true,
cancelable: true
Yes this does what it;s supposed to do, jumps into Edit Mode on the first card in the right sidebar. Is it possible to not go into edit mode but just select the first bullet?
Just press Escape.
I can press escape manually, knew that. I was wondering if it can be simulated inside the dispatchevent function you provided…
I tried the following to get a mousedown event followed by an escape press at the same time with triggering the right sidebar with T R but it doesn’t work like this I suppose:
if (e.key === "t") {
if (e.key === "r") {
if (!span) return
bubbles: true,
cancelable: true
}), new KeyboardEvent("keydown", {
bubbles: true,
cancelable: true,
key: "Escape",
keyCode: 27
I’d like to piggyback this sequence of mousedown+escape to the function triggered by pressing T R (Toggle Right) … would that be possible?
Try this:
const div = document.querySelector(".sidebar-item")
if (!div) return
const span = div.querySelector("span.inline")
if (!span) return
bubbles: true,
cancelable: true
function escape(){
const ta = div.querySelector(".block-editor")
if (!ta) return
ta.dispatchEvent(new KeyboardEvent("keydown", {
bubbles: true,
keyCode: 27
setTimeout(escape, 300)
