I already have like the folders setup. But my doubt comes in the use cases or workflows thati can use
I mean:
- What should I use logseq for?
- What should I use obsidian for?
- What workflows do you use?
I really like both apps but I don’t have that very clear. I cannot differentiate the use cases between both of them.
Thanks and have a nice one
I understand, thank you very much. If you can help me, what are the things missing from each app?
Following on this, I’ve heard that Obsidian and Logseq use slightly different markdown implementations that could cause problems when using both with the same files/database?
Yes. To support their features, they need to save their files in some extended form of markdown, which is not fully compatible to each-other. The resulting problems vary a lot, but many users manage to use both applications (on the same files) successfully.
Good to know. Thanks for confirming. I’ll experiment
