How do I set a new location for my Logseq?
Everything Im finding is way too technical for my brain. Is there a way I can point Logseq away from my iCloud account to a place I’ve copied it to? Thanks
I believe you would just “Add new graph” and select the folder you copied to.
I think that worked. Perfect. Thanks a lot.
So anyone know how set new location for database version?
unable to find that! I just moved to db version after using the md version for over 3 years.
