If some block are just created with a page name and nothing else such as [[jobs]], how do I to test it with advanced query? thank you in advance !!
I don’t fully understand your description, but try this:
:query [:find (pull ?p [*])
[?b :block/page ?p]
(not
[?o :block/page ?p]
[?o :block/content ?c]
[(!= ?c "")]
Thank you mentaloid. But why this codes won’t work the same as yours?
[?b :block/page ?p]
[?o :block/page ?p]
[(= ?c "")]
[/quote]
- Here is the meaning of:
- your code:
; (should have) [?o :block/page ?p] ; (at least) one block [?o :block/content ?c] ; that its content [(= ?c "")] ; is empty
- my code:
(not ; should have not [?o :block/page ?p] ; (even) one block [?o :block/content ?c] ; that its content [(!= ?c "")] ; is non-empty )
- your code:
- Thus it is the difference between:
- your code: “should have a block empty”
- other ways to express the same:
- “should have some empty block(s)”
- “should not have only non-empty blocks”
- “should not have all blocks non-empty”
- Many pages contain some empty blocks.
- my code: “should not have a block non-empty”
- “should not have any non-empty block(s)”
- “should have only empty blocks”
- “should have all blocks empty”
- Few pages are totally empty.
- Because we deal with the emptiness:
- not of a single block with only two cases:
- is empty
- is non-empty
- but of multiple blocks
- any of them may or may not be empty, so the cases are:
- none of them empty
- some of them empty and some of them non-empty
- this represents multiple cases in itself
- all of them empty
- Therefore, if you ask for “should have all blocks empty”, to achieve it we need three negations:
- not have
- the outer
not( )
- the outer
- not even one
- for datalog, one is always enough
- it would be nice if datalog had a direct way to say “all”
- not empty
- the
- the
- not have
Thank you so much for explaining that details. I read couple times to get with you. I have been using SQL for more than 10 years. Dadalog is quite different from it. The most cases just try and error to get to get done.
