i create a single block and want to add some properties, it turn into another block, sometimes it works(or i paste some content with properties), how to add block properties regularly
Welcome!
Properties must be part of the same block you want to add them to. To that effect, type Shift-Enter instead of Enter before typing a new properties line.
In general, the default rule is: Enter will create a new block, and Shift-Enter will add a new line to the current block.
Also, to systematically add properties to new blocks, you may want to set up a template when you’re more familiar with the interface.
I hope this helps!
I use text snippets or expanders in order to achieve that (in my case, Espanso). For instance, I type /ij at the end of each interstitial journal block entry:
tags:: note/ij
alias::
up::
down::
x::
