Hi there,
I would like to know if there’s a way to copy or export the results generated by an advanced query in Logseq. Any help or suggestions would be greatly appreciated!
Plugin “logseq-cuvee” seems only works for queries, not advanced query
I don’t have a solution for the generated results. But if you want to copy a raw list of contents (for returned blocks) or names (for returned pages), I can prepare some custom code.
Thank you so much! I really appreciate your offer for custom code. In fact, I need to copy the results of the following advanced query:
{:title "🔙 All Backlinks in Current Page"
:inputs [:query-page]
:query [
:find (pull ?refpage [:block/name]) ; only care about block name
:in $ ?current
[?b :block/refs ?refpage] ; blocks with references
(not [?refpage :block/journal-day]) ; not a journal
[?p :block/name ?current] ; get current page
[?b :block/page ?p] ; block must be on current page
:view (fn [res]
[:ul (for [row res]
[:li [:a {:href (str "#/page/" (:block/name row))} (:block/name row)]]
- Preparation:
- Add a macro inside file
config.edn, insidemacros{}:
:copyparent "<button class='kit eval' data-kit='copyquery'>► copy query results of parent block </button>"- The code below requires having kits inside file
custom.js. - Inside page
CopyQueryin Logseq, put the following code in a javascript code-block:const LS = logseq.api const Module = logseq.Module const Kits = Module.Kits const Msg = Module.Msg function advancedQuery(content, queryWord){ const queryStart = content.indexOf("[", queryWord + 5) if (queryStart < 0) return var queryEnd = queryStart + 1 var n = 1 while (n > 0) { const close = content.indexOf("]", queryEnd) if (close < 0) return const open = content.indexOf("[", queryEnd) if (close < open || open < 0) { queryEnd = close + 1 n -= 1 continue } queryEnd = open + 1 n += 1 } return content.slice(queryStart, queryEnd) } function simpleQuery(content, queryWord){ const queryStart = queryWord + 6 const queryEnd = content.indexOf("}}", queryStart) return content.slice(queryStart, queryEnd) } function getBlocks(content, queryWord){ if (queryWord < 0) return if (content[queryWord - 1] === ":") { const query = advancedQuery(content, queryWord) if (query) { const name = query.includes("?current") && '"' + LS.get_current_page().name + '"' return (name ? LS.datascript_query(query, name) : LS.datascript_query(query)).flat() } } else if (content.slice(queryWord - 2, queryWord) === "{{") { const query = simpleQuery(content, queryWord) if (query) return LS.custom_query(query) } } logseq.kits.copyquery = Kits.addClickEventToButton.bind(null, function onCopyParentClicked(e){ const child = e.target.closest("div.ls-block") const parent = child.parentElement.closest("div.ls-block") const blockId = parent.getAttribute("blockid") const block = logseq.api.get_block(blockId) const content = block.content.replace(/\n?.*[:][:].*\n?/g, "\n").trim() const queryWord = content.indexOf("query") const res = getBlocks(content, queryWord) if (!res) return Msg.ofStatus("Missing query", "warning") const out = [] res.forEach( (r)=>{ const name = r.name if (name) out.push(name) else out.push(r.content) }) navigator.clipboard.writeText(out.join("\n")) Msg.ofStatus("Copied " + res.length, "success") })- This code makes plenty of assumptions, so:
- it will work with the specific query
- it will work with some other queries
- it will not work with many other queries
- To make it work for a specific query, provide it here to see what can be done.
- Usage:
- Put the macro at a child block under the query:
- i.e.
{{copyparent}}
- i.e.
- Press the button. This should automatically:
- run the query of the parent block
- copy everything returned as text separated by new lines
- show a success message with the number of copied items
- Paste somewhere the content of the clipboard.
Thank you so much for your help, it worked! You really saved the day.
I don’t have much of a coding background and I never knew that Logseq could be extended in this way. I’m thrilled and I definitely want to continue exploring more. I really appreciate your guidance.
I used GPT to modify the copyquery code to make the results appear as links, which better suits my needs. Here’s the modified code:
const LS = logseq.api;
const Module = logseq.Module;
const Kits = Module.Kits;
const Msg = Module.Msg;
function advancedQuery(content, queryWord) {
const queryStart = content.indexOf("[", queryWord + 5);
if (queryStart < 0) return;
var queryEnd = queryStart + 1;
var n = 1;
while (n > 0) {
const close = content.indexOf("]", queryEnd);
if (close < 0) return;
const open = content.indexOf("[", queryEnd);
queryEnd = close + 1;
n -= 1;
continue;
queryEnd = open + 1;
n += 1;
return content.slice(queryStart, queryEnd);
function simpleQuery(content, queryWord) {
const queryStart = queryWord + 6;
const queryEnd = content.indexOf("}}", queryStart);
function getBlocks(content, queryWord) {
if (queryWord < 0) return;
const query = advancedQuery(content, queryWord);
if (query) {
const name = query.includes("?current") ? `"${LS.get_current_page().name}"` : null;
return LS.datascript_query(query, name).flat();
const query = simpleQuery(content, queryWord);
if (query) return LS.custom_query(query);
logseq.kits.copyquery = Kits.addClickEventToButton.bind(null, async function onCopyParentClicked(e) {
const child = e.target.closest("div.ls-block");
const parent = child.parentElement.closest("div.ls-block");
const blockId = parent.getAttribute("blockid");
const block = await logseq.api.get_block(blockId);
const content = block.content.replace(/\n?.*[:][:].*\n?/g, "\n").trim();
const queryWord = content.indexOf("query");
const res = getBlocks(content, queryWord);
if (!res) return Msg.ofStatus("Missing query", "warning");
const out = [];
res.forEach((r) => {
const name = r.name;
if (name) out.push(`[[${name}]]`);
else out.push(r.content);
navigator.clipboard.writeText(out.join("\n"));
Msg.ofStatus("Copied " + res.length, "success");
Thanks again for all your help!
I installed Kits fine and the
{{evalparent}}
works fine. I added your button
{{copyparent}}
and, while it worked at first, stopped working completely even thought the evalparent buttons still works. I’m trying to use the code on a simple query since cuvee doesn’t work anymore. This is my query
{{query (and (property :year [[2025]]) (property :month) (property :status) (sort-by month asc) ))}}
Any assistance you can offer would be appreciated.
I’ve restarted logseq several times with no luck. I just need a CSV output.
I added the code from the previous reply to my config.js file but I’m not clear how to get the button on how to run the code. Any support would be appreciated.
What has changed in between?
- What is “cuvee”?
- I have made a change for advanced queries, please try the new code.
- If the problem remains, check the console for any errors (open with
Ctrl + Shift + i).
Thanks for making the change. Where would I find the new code?
Cuvee is an old plugin that would have solved my problem but it doesn’t work anymore as it has not been updated in 3 years.
Nothing changed in between that I can determine. However, my graph is stored on OneDrive so I wonder if that has something to do with it.
The new code is exactly where the old code was (i.e. on the same post), as it has replaced it. Just update the code of page CopyQuery with the one in the post (which is now the new code), restart Logseq, then try again.
The only potential problem concerning the storing place is if the content of a file is not the expected one. As long as the content is correct, it doesn’t matter where it is stored.
Thanks. I will try it out. I moved my graph off of onedrive into a local folder and the script seems to work their fine. This is so weird. I found that, when on onedrive, I don’t always see the Kits message when I launch logseq. I wonder if it’s possible to keep the config files in a local folder and point logseq there. Moving my graph out of onedrive isn’t ideal for me.
Great! It works now while on onedrive.
What would help, if possible, would be a message that confirms that the info was copied.
There is already a confirmation message, as seen at the last statement of the code. It appears for a few seconds at the top-right of the window.
Check file config.edn for entries custom.css and custom.js
Ok I will pay attention to the top for notifications then. Thanks for your help and I will check those files.
@mentaloid The query worked for me but only copied the properties and not the child blocks. My query result looks like this
and this is my query
Here is a basic implementation to include children:
- Add in the code this function:
function pushChildTree(child){ const block = LS.get_block(child[1]) this.push(block.content) block.children.forEach(pushChildTree, this) } - Find and replace:
- these lines:
if (name) out.push(name) else out.push(r.content) - with these lines:
if (name) { out.push(name) } else { out.push(r.content) LS.get_block(r.id).children.forEach(pushChildTree, out) }
- these lines:
- Restart Logseq.
This worked like a charm. Thanks
I’ve change to render html table to markdown table string, and copy to logseq to render.
function tableToMarkdown(table) {
const rows = Array.from(table.querySelectorAll('tr'));
const markdown = [];
// Handle headers
const headers = Array.from(rows[0].querySelectorAll('th,td'))
.map(cell => cell.textContent.trim());
markdown.push(`| ${headers.join(' | ')} |`);
markdown.push(`| ${headers.map(() => '---').join(' | ')} |`);
// Handle data rows
for (let i = 1; i < rows.length; i++) {
const cells = Array.from(rows[i].querySelectorAll('td'))
markdown.push(`| ${cells.join(' | ')} |`);
return markdown.join('\n');
console.log("copyquery click ", e)
const table = parent.querySelector("table")
if (!table) return Msg.ofStatus("Missing table", "warning")
const markdown = tableToMarkdown(table);
navigator.clipboard.writeText(markdown);
Msg.ofStatus("Table copied as markdown", "success");
// const blockId = parent.getAttribute("blockid")
// const block = logseq.api.get_block(blockId)
// const content = block.content.replace(/\n?.*[:][:].*\n?/g, "\n").trim()
// const queryWord = content.indexOf("query")
// const res = getBlocks(content, queryWord)
// if (!res) return Msg.ofStatus("Missing query", "warning")
// const out = []
// res.forEach( (r)=>{
// const name = r.name
// if (name) out.push(name)
// else out.push(r.content)
// navigator.clipboard.writeText(out.join("\n"))
// Msg.ofStatus("Copied " + res.length, "success")
Could someone generate a visual diagram (process map) of how to deploy what is suggested within this thread and what it achieves as a summary?
You don’t need to copy your queries to the CopyQuery page. The CopyQuery page only stores the JavaScript code that enables the copying functionality.
Your actual queries can be located anywhere in your Logseq graph - on any page where you need them. The setup works like this:
- The CopyQuery page only holds the JavaScript code that powers the export functionality
- Your queries (advanced or simple) can be created on any page in your Logseq graph
- Wherever you have a query, you just add the
{{copyparent}}macro as a child block under that query- The button will appear under each query where you’ve added the macro
- Click the button to copy that specific query’s results to your clipboard
This way, you can have multiple queries across different pages in your Logseq graph, and you can add the copy functionality to any of them by simply adding the
{{copyparent}}macro as a child block.
