Is it possible to export or copy as text without the double square brackets (wiki links)?
Yes. If i understand correctly, you just need to look at the checkboxes under the text window when you rightclick on a block or page and “export”. There you will find one that says “show brackets” or something like that.
Found it. Thank you!
