How to do a progress bar
Hi :slight_smile:
Browsed some themes, and saw one which had a progress bar / progress indicator in the example screenshot. I was just wondering if anyone knows how you make those progress bars? Could it be a plugin?
The theme with the progess bar in the example screenshot: https://github.com/pengx17/logseq-dev-theme
It is [:progress {:max 10 :value 3}]
Alright :slight_smile: Thanks alot.
Where can I find more β€œhidden” features like this?
Welcome. Unfortunately, the only place that gathers such features is the codebase itself. Otherwise they are scattered here and there (docs, forum, discord etc.)
