Hi there! I am using templates for my page generation.
For example, i have one query as:
{{query (and (todo now later) <% current page %> ) }}
But instead of allowing template generation to substitute the variable, I would like to keep it intact - query would work the same way either way and we would avoid hard coding the page name.
I would need to escape once, so after page generation it would land as correct statement.
It was not generating at some point. I just tested and it is working at the moment. Also, I think I may have misunderstood your question at first.
On a page, when you have {{query (and (todo now later) <% current page %> ) }}, the dynamic variable will remain. However, with a template the variable will be substituted. Because the idea here is that, the template would substitute as much to give you a desired output by evaluating variables. In short, your ask is to turn off the substitution of the variable, which I do not think is possible. Feet free to open a feature request
It’s because having a dynamic variable as is in non substituted form has a value on a target page
Usually in any templating language you have an ability to escape the special characters so they are realized in original form.
So instead <% current page %> you could write <<% current page %>> and in generated page we would get a query using dynamic variable in proper form, not hard coded value.
