How to export or copy a page and include linked references?
I can’t figure out how to get all notes for a tag or page from Logseq. I can’t highlight everything and copy to clipboard and exported pages leave out linked references.
Not currently possible. Should look for some export plugin in the marketplace.
Thanks for directing me. I tried a couple and the one that comes closest to exporting a page with linked references is supery-chen/logseq-plugin-pdf-print. Unfortunately the export it produces is in image format and not text in the exported PDF. One would have to OCR the PDF.
I have a similar question here. I wnat to copy the texts (the contents) of the linked references in one page. Any suggestion to do it?
Check Macro to auto-embed a block to the page of a tag
Hi Thank you for the fast response. But what I need is to copy the texts and not the block embeds.
Maybe I could explain a bit more. I’m using a different graph and I want all my flashcards (the blocks that are tagged with #card) to be copied from one graph to another. But when I clicked #Card in Logseq, the contents are presented in the linked references. I want to be able to copy just the texts in those linked references and paste to the new graph. (so that I can also review the flashcards in the other graph.)
I wrote a step by step blog to export linked references for a specific tag in Markdown. Here: https://www.abhinav.ai/post/logseq-export-blocks
you can also try this plugin “doc-view-exporter”, it can generate a html file including linked references
