Hello, I’m a newbie here. I can see there is an option to ignore directories in config.edn but it seems not functioning. I don’t know if the problem is either because I type the directory in a wrong format inside the config.edn or because it can’t ignore directories from Github repo. Please help me!
You just need to add the directory to the .gitignore file. The file doesn’t exist by default.
Check out .gitignore file - ignoring files in Git | Atlassian Git Tutorial
Oh yeah. That makes sense. I’ll try your suggestion. Thanks.
I have tried clear cache and unlink my repo then link again. The problem solved. I didn’t include the directory in .gitignore
Awesome, glad you figured it out!
You can mark your reply as a solution in case someone else encounters the same issue in the future
Ok. Thank you for reminding me.
