How do I increase the size of the drop down arrows or triangles that indicate content underneath that is hidden? I find the size of the these triangles and bullets so small and light that I often miss them. (The font size on the text is okay, though.)
Yes, this helped a lot. The arrows and bullets are now larger, easier to see. If you have a moment to tell me how to make them darker (they are very light gray) that would be great.
The arrow is now darker, so thanks! I would like to make the round dots darker as well. So I took what you wrote and using that as a model I added fill: black as part of the .bullet-container.bullet part. See below, but it didn’t make a difference.
This is awesome! Is there a way to make the rotating arrow always available when there are collapsible sections like the NOW/LATER section below the journal page?
