You are right, I am on Mac. Thank you so much.
I downloaded the file, unzipped it twice, and drag the logseq file into Apps. It turn out to be the MD version, probably the DB version still not available for desktop yet.
If you want the DB version, ensure that when you are on the GitHub Actions page, look for the Build-Desktop-Release workflow that is tagged with the master branch.
