How to make a template including properties in Logseq DB?
I want to make a page template like that. But the template can not include the page property.
If I need to add the property under the node?
It is hard to add a new property on this way. Because there is no button “Add property”. I have to use /Add new property each time.
So could you please tell me how to generate a page template including properties?
I need a some clarification:
Do you want to have properties charaterizing a book to be added to the a new book when you create one? if so, this does not require a template, but just a tag: book
Next, do you want some nodes to be added to a book page; and some of those nodes to be property base? if so, this will be with a template, associated with a the tag: book
I can show an example upon clarification
Oh. Thanks. I find the answer on youtube.
It is a different way from old logseq.
I create a Tag named Book.
And I add the Book tag to a page. But it still has not propertiest.
Is there anything I should do more?
I find that.
I need to add in the Tag Properties
That change was introduced a few days ago. You must add those tags under Tag Properties
Those page properties will only be on the #book page, and not on each new book. But Tag properties will apply to all book.
I want to ask a new question.
Because there are some places different from old logseq.
When I input file into DB graph, I find most of query not work.
Because it can not search the [[ ]] in text property.
Although node property can do it.
You know, the type of property can not be modified.
So how I repair the query?
@danzu
