My problem:
On any page, when you click on a textarea block to enter its editing state, the display position of the block noticeably jumps (more specifically, it moves up). Although the amount of movement is small, it is clearly visible. However, there is no such problem for heading level block.
Expected outcome:
The expected outcome is that when you click to enter a block editing state, the display position does not change.
It is possible to solve this problem by maintaining custom.css file.
Environment information:
logseq version: 0.9.8
Windows 10
