i want open existing page or link with keyboard shortcut in the note.(equals to mouse click), in obsidian, this shortcut is ‘alt+enter’.
i found ‘alt+enter’ to zoom editing block, not to open the content of the page or link.
how to do it?
thanks, best wishes
I have been searching for ages to figure this out too! I can’t quite accept that there is not a keyboard shortcut to just “open a page”, so I felt like I was the weak link. I also tried removing plugins to see if they had messed up my shortcuts. No luck.
So basically, I’m able to use the arrow keys to move up and down a list of links, but I must reach my hand to the mouse to actually click it and open it. Sounds so trivial, but it really annoying.
Any suggestions would be much appreciated.
While in edit mode, put your cursor over the link then hit ctrl + o (letter). It works on the Linux version. I’ve found some shortcuts don’t work on all versions though some experimentation around the suggested link can lead to finding the link you want.
Nice one ![]()
Works on Mac as well. At least for me.
Yes, but on Mac the shortcut is Cmd + o; if you press Ctrl + o when the cursor is on a link, it’ll open the linking autocomplete.
For others stumbling upon this thread and wondering what are the shortcuts in Logseq, you can see all of them (and reassign shortcuts) via ? (in bottom right) > Keyboard shortcuts:
The shortcuts displayed by the app do not necessarily work for all of the various versions of Logseq. I found that some shortcuts were impossible using the Android version of Logseq while others didn’t work at all.
The shortcuts are indeed only for desktop; I’m not sure if the devs even intended for the shortcuts to work on Android.
And what shortcuts weren’t working? Because that should then be reported as a bug (I can do that but you’ll have to tell me which ones you found to not work).
