I have a project templates look like this:
projects/sample-project
project-name:: this is the full name of the project
due:: 2023-10-31
Now I want to a query in my main project
entrance that looks like this
How do I write this kind of functions?
Is this what you’re looking for?
{:title [:b "Projects past due"]
:inputs [:query-page :today]
:query [:find (pull ?p [*])
:in $ ?page ?today
[?prj :block/name ?page]
[?p :block/namespace ?prj]
[?p :block/properties ?prop]
[(get ?prop :due) ?due]
[(re-pattern "(\\d{4})-(\\d{2})-(\\d{2})") ?rx]
[(re-find ?rx ?due) [_ ?yyyy ?mm ?dd]]
[(str ?yyyy ?mm ?dd) ?day]
[(str ?today) ?stoday]
[(< ?day ?stoday)]
Sorry for the late response,
This is the result after input the query above
re-find must match against a string.
Does it means the [(get ?prop :due) ?due]
does not assign the ?due as a string?
No worries.
It shouldn’t? If your due is formatted as you said due:: 2023-10-31
it should be a string.
Here’s a screenshot from my test graph.
Oh wow thanks for pointing it out, and sorry for my negligence.
My property is actually a link to dates in format of #[[2023-10-31]]
I modified a few lines of code as following
for some reason it shows all the project when supposedly only selected one should appear
What’s wrong with my modification?
So due will be a reference whereas today is an integer. That’s why your modification doesn’t work. However instead of properties we can use the attribute properties-text-values and due will be a string.
Like so:
:in $ ?page ?today
[?p :block/properties-text-values ?prop]
[(< ?day ?stoday)]
