With the help of
Full House Templates plugin.
Look at the demos:
This is helpful if you’re using Logseq for writing: details of characters, world description, role playing games, etc.
Setup instructions are here.
With the help of
Look at the demos:
How did you achieve the two-column effect?![]()
In this particular animation with the help of Side Block plugin.
Also Im using Missing Commands & Views plugin to be able to use different block layouts with #.tabular, #.columns, #.gallery tags:
