Hello,
I’m trying to remap the keyboard shortcut “Move cursor to end of block” to the “End” key. The shortcut appears in the keyboard shortcut list (g s), but won’t allow me to modify it from “Ctrl E”. I’m looking to edit the config.edn file with:
Since the command is executed, it appears that remap is working. Admittedly, it’s not a good description of how it works. I use Logseq and occasionally run into problems with wording like that.
Thank you for the suggestion. I’m using it on MacOS and for some reason the option to remap it is greyed out (and that’s why I wanted to try the config route):
