How can I set the visibility of the :LOGBOOK:
data of my tasks? E.g. Can I set them in config.edn
They make my task list noisy.
I did not find any information about this in the forums.
Yes, search for :logbook/settings
in the config file.
;; logbook configuration.
:logbook/settings
{:with-second-support? false ;limit logbook to minutes, seconds will be eliminated
:enabled-in-all-blocks false ;display logbook in all blocks after timetracking
:enabled-in-timestamped-blocks false ;don't display logbook at all
