How to set Logseq to collapse "Linked References" by default, similar to "Unlinked References"?
Hi everyone,
I’m seeking help on how to configure Logseq to collapse “Linked References” by default, just like it does with “Unlinked References,” particularly on the Home (Journal) Page.
I have imported numerous linked reference pages from other sources, such as Readwise. Currently, the “Linked References” section is expanded by default, which causes the home page to become laggy when I try to scroll through the entire page.
Any guidance on how to adjust the settings to automatically collapse “Linked References” would be greatly appreciated!
Thank you in advance!
Had exactly the same issue, but managed to solve it by scrolling through the entire config.edn document, which can be opened easily via Settings > General > Custom configuration > Edit config.edn
Find the line with ref/linked-references-collapsed-threshold and change it to 0. Mine is like this:
:ref/linked-references-collapsed-threshold 0
Hope that’s what you are looking for!
