I can’t find a way to start editing something w/o clicking the mouse to focus on what I’m gonna edit.
For example, after navigating with Ctrl ]
/ Ctrl [
Logseq exists the editing mode and I can’t edit anything until I click the mouse which makes using the navigation shortcuts sort of useless.
When you end up on the page you want you can use the arrow up and down to go to the block you want to edit. Then the left arrow will start editing at the front of an existing block and the right arrow will start editing at the end of the block.
But I did see that the browing up and down the blocks is not working consistently. That is a regression from earlier versions I think.
Right, it works now.
Weird as I thought that I tried UP/DOWN and it didn’t work :-/
