I am using Google drive to sync the Logseq graph (folder with 5 folders in it) which works good.
However, when I install Logseq on another PC and open the synced folder, all documents are loaded but the installed plugins that were installed, are not installed. Now I need to again install the same plugins as the other PC.
Is this normal behavior?
Thanks
