How you use logseq DB with openclaw?
OpenClaw has been very popular lately, and people are already trying to connect Obsidian to it.
Are there any ways for Logseq DB to connect to OpenClaw? For example, if I purchase the Logseq DB sync service in the future, will there be a channel provided so that OpenClaw can interface directly with my remote data server?
I found some “MCP Server” documentation. You will understand it better than I.
Like everything, it is work-in-progress …
The preview here doesn’t scroll to the right bit: click “show original”.
From the Unofficial FAQ:
  • The Logseq MCP can interface with online LLMs like Claude or OpenAI, or offline ones, like Gemma, to let you directly interact with your graph. Like the API, this requires using the desktop app, not the web app (see above).
There are some unofficial MCP servers on Github: next post is a list.
I’m currently using the markdown version of Logseq with OpenClaw, working directly with the filesystem. I’ve been interested in trying graphthulhu for a more proper MCP integration, but it would need a patch to work headlessly (without the Logseq desktop app running).
My current setup includes:
  • Two separate Logseq graphs: one for my research notes and one for auto-ethnographic journaling for the assistant
  • Custom skills for reading/writing Logseq pages
    • zettelkasten linking and note-ID management
    • also creates block references to maintain proper linking
  • Automated research pipeline: A daily cron job fetches academic papers via matcha (feed aggregator), then OpenClaw reads the results, condenses them, and sends me a summary with only the most relevant papers, and saves them to Zotero and in some cases to Logseq
    • The workflow goes something like this: Paper discovery → triage → Zotero annotations → OpenClaw writes research notes directly to Logseq with proper cross-references and zettelkasten IDs
That said, I honestly have no idea how I’d migrate to Logseq DB at this point. My entire workflow is so markdown-oriented — direct file access, git-based syncing, filesystem automation with scripts. The DB version seems to abstract all of that away, which is great for some use cases but makes me nervous about losing the control and integration points I rely on.
If anyone has experience migrating from MD to DB while maintaining heavy automation/scripting workflows, I’d love to hear tips or warnings! Especially curious how people handle:
  • Git-based version control and syncing
  • Direct file manipulation by external tools
  • Automation that reads/writes notes programmatically
