HTML tags are not rendered correctly when they are in the middle of a word
Example with characters before the tag:
Screenshot_20230813_141817
Example with characters after the tag:
Screenshot_20230813_142031
Mostly relevant for underline <u>/<ins> as bold and italic have markdown support and are rendered correctly.
Try this:
t @@html: <u>est</u> @@
It invokes using slash command ‘Embed HTML’
Thanks, that’s clever! @@html: t<u>est</u> @@ works.
Not sure if I can mark your answer as “Solution” w/o essentially trashing this bug report. Probably it’s still useful if this was looked into at some point, as there is no easy way to use underline currently (although Bad3r had a go [WIP] feat: support underline for markdown and update string format pattern by Bad3r · Pull Request #9245 · logseq/logseq · GitHub).
And if someone is visiting this thread looking for some answer this plugin might be of interest: GitHub - sethyuan/logseq-plugin-wrap: Create your own wrappings with optional key bindings for selected text, a set of useful defaults is also provided.
