I can't exit logseq without having to force-quit. Overall macOS system slowdown
My setup: I am running a large logseq database using the Readwise plug-in. Around 19000 pages. Running on an M1 Mac mini and 16 GB of RAM. All files are sitting outside of my iCloud folder.
It might be a difficult one to pin down, but in effect I’m experiencing an overall slowdown of my macOS system when logseq is running (closing all other apps except for Safari). If I quit logseq or restart the computer the problem fixes itself.
Then, I find myself having to force quit or cancel the process from the Activity Monitor. CPU and memory usage remains fairly under control, with no big spikes.
What actions can I take to start debugging the issue? Perhaps the Readwise plugin has something to do with it?
I tried re-indexing the database doesn’t do much of a difference.
Do you use logseq sync by chance?
Can you record a performance profile?
No logseq sync. However, on that directory I am running a git repo to publish my changes.
That could be part of the issue.
Yes,
Here you go:
https://drive.google.com/file/d/1Juy8Lkm7TO6otHg7QBzopGR-Ry48Nglj/view?usp=share_link
Given the exception event captured:
Any console output captured when you exit the program?
Seems to be the case of Unable to close Logseq · Issue #8536 · logseq/logseq · GitHub
But we have no deterministic way to reproduce the issue.
Do you have any clue to reproduce it?
Is this issue happening on a new graph?
Is this working for you?
I did have git auto commit enabled, it is now disabled and appears to be working.
yeah , git auto commit was the problem , thx
