You’re welcome! Before I tried Logseq, I downloaded both Obsidian and Logseq to see which one I would adapt to more easily because they are entirely new styles of note-taking apps. I wasn’t sure if they would work for me.
In terms of syncing abilities, Obsidian is much better, but Logseq’s outliner design resonated better with me. However, syncing with GitHub compensates for the problem. It took me a few days to figure out GitHub since version control is a new idea for me, but after understanding it, I realized it’s a better solution and it made me feel more secure than Apple Notes. Another interesting thing I discovered is that I don’t have to use just one note-taking app. As long as I record my ideas and words, I can collect them in Logseq. It’s like having a personal Wikipedia where I can store all the valuable information I find in the world. And because it uses markdown files, I can easily switch between different applications.
Now, let’s go back to how it all started.
I gave myself 2-3 days to see if I could make Logseq work better than my original solutions, Notion and Apple Notes. Luckily, I solved my problem within the expected time.
I think the problem lies in the difference in design. The use of tags and links allows you to see everything within the link. It’s not just a simple fancy feature; it actually works better with my brain.
I have to admit that I have some bad memories from my childhood, and I tend to forget things. When I have emotional issues (a bit like PTSD, experiencing flashbacks to bad feelings for hours and days),
But as long as I keep using timestamps to track the flow of time and write down my feelings and what I had done in a day, it can reduce my negative thinking. And as the links within the notes connect with each other, you can find something very interesting. You can discover how your ideas were formed and how everything began.
Perhaps digital devices, the internet, and short videos have made my memory more fragmented, and traditional paragraph note-taking is too slow. You don’t need a specific subject to write things down; just tag anything you like, and someday you’ll figure it out by yourself.
The most important thing is to type/write down your thoughts and then tag them. The linked references will help you figure out “why” and “how.” Without the link reference, I would easily forget my notes.
This time, instead of selling me things or advocating ideas, computers are finally helping my thinking in our busy daily lives.
I think I’m too excited about what I found. Blah blah, become a wordy person.
