I want to be able to edit using the floating window
It is hoped that the work can be done by floating the window
The folded node can also display the folded information through the floating window
The sibling nodes can then be quickly collapsed
This is an article about some of the most amazing features I found when using Roamedit
Amazing features of Roamedit
I want to be able to use a floating window on logseq and display nodes in place as mind maps
v2-3a25026e47c5fafa0471e3129a9cfb05_b
In this article, in this article, I easily handle the structure of the article through the folding node, and then open the folded node through the suspension window, which can quickly view the contents of the folded content and do not lose a large view
