[](https://example.com)
It seems this and any other Markdown syntax to turn an image into a clickable link doesn’t work
You can use the syntax to display the image
To link to the image, simply remove !
[image](url.png)
I mean, the syntax I posted usually turn an image in clickable object and clicking on it open a URL. Check the example code I posted
Reported on GitHub:
