I have open an issue on Github (Password dialog auto hides making imposible to decrypt a graph · Issue #2305 · logseq/logseq · GitHub) and had zero feedback from developers except a guy that had same problem.
Basically when I try to decrypt a graph, the password dialog shows and after 1 or 2 seconds autohides/autocloses on my iOS and Android devices, making it impossible to type in anything. Logseq after hiding it, starts to decrypt the graph!! with no success, of course.
In Desktop you have the same problem but if you click the reload button (not available on mobile deices) you can bring the dialog back and then you type in your password.
So, my question. Is there anyone using encryption and not having problems or it’s a problem on my side that I need to investigate deeply?
