Is there any plugins that supprt inputing the chemical formula?
Logseq supports MHCHEM extension for Katex. Just put the code in between $$code$$ or $code$
Thanks , l will try it.
And how to print the one-way arrow?
This link js all you need Chemistry notation using mhchem - MoodleDocs
Thanks! It’s very useful!
Thanks, this is great!
Do you know, if there is a tool for inputting structures too?
I rememer it is also in the documentation. If not, you can google it yourself!
Let me google that
I’m afraid you remember incorrectly; the document is about formulae, not structure.
To me, this comes off as rough and a bit harsh. I would like to ask you not to provide advice to me this way in the future.
Thanks in advance
