On Obsidian, I was able to get the local weather using this curl command. How do I or can I relicate this for Logseq?
If not , hope someone is writing a plug in soon
Maybe ask this godsend: GitHub - sawhney17/logseq-web-parser
You can use the Logseq smart blocks weather command to insert current weather
thanks , tried this, but most web pages contain too much information other than just today’s weather. So parsing will end up with a lot of unncessary information. Thanks for the suggestion anyway, I may use this for something else
sorry for being dumb here, how exactly do I do that?
