Is there a way to add a mindmap?
Something like this https://lattics.zineapi.com/
Welcome. If you mean:
  • to import a mindmap:
    • Logseq can import markdown.
    • So the question is whether the mindmap to import has a markdown format.
  • to create a mindmap:
    • the data structure: Logseq has graphs, which is a superset of mindmaps.
    • the visuals: Can use the Whiteboards feature.
Also there’s a markmap plugin GitHub - vipzhicheng/logseq-plugin-mark-map: This is a plugin for https://github.com/logseq/logseq to provide mindmap support based on https://github.com/gera2ld/markmap. to view page as a mindmap.
