Is there a way to control the displayed label of nodes in the right sidebar?
When a node is opened in the right sidebar, the title or label of the dropdown is always that of its parent node (which in my case is often the journal date).
As you can see, if you have multiple nodes from the same parent in the sidebar, there is no way to distinguish between them. Apart from the problem of having multiple nodes from the same parent in the sidebar, it is often the case that having the actual block text as the label is the desired behavior. For example, in this scenario:
It would make more sense to just have the text of the block as the label because it is the significant thing I am trying to view.
Is there any way to achieve this through configuration or themes, or is this a feature that should be requested?
