Is there a way to filter flashcards?
If so, how?
Yes there is, you would create groups of cards by tagging them, and then reviewing the cards with the specific tag:
- {{cards([[testgroup1]])}}
- {{cards([[testgroup2]])}}
- Subject 1: [[testgroup1]]
- What is this? #card
- This is a test
- What is this then? #card
- This is a second card
- Subject 2 [[testgroup2]]
- More questions? #card
- Yes, it is so
You can also tag an individual card:
- What is a gerund? #card #grammar
You can use {{cards + [[query]]}} (ex. {{cards [[logseq]]}}) to filter flashcards with tags
There are two ways to add tags to card
- add tag after
#card
- my flashcard #card #logseq
- answer
- nested (note: you can’t add tag after card)
- Subject 1: [[logseq]]
- answer
refs
Is there a way or workaround to add multiple tags to a section of cards other than taggin them one by one?
Suppose i have thousands of cards, it really would be frustrating to have to tag them individually
This is an example, i even tried to reference properties without success, like in
{{cards (property state mx ) }}
Try to add multiple nested tags doesn’t work, but add them to each card one by one does
I am also looking into ways to filter flashcards
Basically, I am trying to search for cards
- in
namespace - inside page with
alias - with pages of
property
