Hi I was looking for a way to create a whiteboard from a script.
I’d like the idea to use whiteboard as a views of the graph, e.g. if I am studing a writer a want a whiteboard that display all related blocks.
I don’t truly understand yet the architecture of Logseq, if some one could kick me in the right direction would be awesome.
Welcome.
- Typically, a whiteboard in Logseq is an
.edn
file.- This file is inside the folder
whiteboards
- This folder is inside the folder of any graph that contains whiteboards
- If you can work with such a format, you can make a script that outputs any whiteboard inside that folder.
- To learn that format, could:
- begin with the file of an empty whiteboard
- make small incremental changes through the GUI
- observe the changes in the file
- To connect the whiteboard from/to other blocks, should use Logseq’s API.
Thank you Mentaloid!
