Is there a way to paste text without separation into blocks?
I’d like to paste text with a lot of line breaks but all into one block. Currently if I try and paste text that has line breaks, each paragraph gets converted into its own block
Multiline text does paste into a single block on Logseq 0.7.5 on Mac and Android. Not sure about Windows.
here’s a trick. Create a block quote ``````, paste into it, then remove the quotes
I’ve had the best luck using quote blocks.
#+BEGIN_QUOTE
My quote
#+END_QUOTE
Hi,
I need the opposite behaviour… I want to paste multi-line text, and that every line becomes a block… but no luck!
any idea how to reverse that (i.e. past text with each line as a separate block)?
Regarding multi-block pastes have you tried the plugin paste-more? It usually does a good job of breaking things up into separate blocks for me.
As far as my testing with Logseq 0.8.2 I find Cmd V will paste separate blocks for each text line, and Cmd Shift V pastes all text lines into single block on Mac
This is what I was looking for. Thanks!
Also it removed any links and metadata so it was text only. That’s what I was looking for anyways.
Can anyone kindly suggest what is an alternative to this on windows, Ctrl + shift V isn’t working
