Hello,
This is my use case:
- Some of my pages have the tags:: property on line 1 and a sequence:: property on line 2
- ex: tags:: a,b,c
sequence:: 1
- I use an external python script to adjust the values of the sequence:: property value for all necessary pages based on some external logic
- I checked and all pages do have the necessary data after running the script
- Then I have a query with “sorted-by” so I see my pages in order
- That way I can reorder my pages/scenes as needed without to go change the property value manually
I noticed that, initially, my query does not return anything.
However, as I go to each page and click on the property line, the page gets “recognized” by the query.
It seems to me, I need to “force” Logseq to recognize I have properties in that page.
I tried to “refresh” as well as “re-index”, but none help.
Any clue of what I am doing wrong?
Regards,
Philippe
Hi,
Thanks for your feedback.
This is the query as seen in LogSeq:
{{query (and (page-tags [[act_i]]) (page-tags [[hc]]) (page-tags [[encounter]]) (page-tags [[story]]))}}
This is what I see using Byword to edit the md
||- {{query (and (page-tags [[act_i]]) (page-tags [[hc]]) (page-tags [[encounter]]) (page-tags [[story]]))}}|
|| query-sort-by:: sequence|
|| query-sort-desc:: false|
|| query-properties:: [:page :sequence]|
I have checked the three first advices but I discovered Logseq 4 days ago … can’t say I am that confident my query is good
Checking on the Javascript and the internal Python support
I wanted share my test files here but could not find a way to upload a zip
Regards,
Philippe
Hi,
I have not changed the script and cannot reproduce the issue now merging the “test” scenes with my real notes - will keep trying:
tags:: HC, Encounter, Story, Act_I, Scene
sequence:: 2
- #Synopsis:
- text
- #Script
- #Panel
- Text
- #Panel
- Text
Regards,
Philippe
