Issue with creating task, probably messed up database scheme
I am unable to create tasks by tagging a node with #Task or by using control-enter. Hitting control-enter simply doesn’t do anything. When typing #Task inline, it does seem to create a task out of it, but. I am unable to change the status to anything else. When I click on the “Todo”-circle, I do get a “Set status”-pulldown menu, but selecting an other status doesn’t do anything.
I assume this is the case since I’m a long time user of Logseq, migrated from the Markdown to the Database-version and did do some experimenting. I guess I must have messed up with the definition of #Task-tag along the ride. It must be specific to this database, since when creating a new database, it works as expected.
So, my question is, how could I restore this behavior? Is there a away to update the database, to re-create the database structure in order to have these tasks working again? Or should I look at something else?
