I’m trying to check for food intolerance. I use Logseq to keep a daily journal, and I would like to extend it to record food I eat and symptoms to see if I can spot any trends.
Does anyone have a recommended way to do this in Logseq (if it’s possible).
For beginning I can recommend to use templates.
Check https://docs.logseq.com/#/page/templates
or/and Using templates in Logseq to simplify workflows (and a brief intro to "Properties") - YouTube
It will help to be consistent and will speed up the process.
You can also create repeated TODO task do not forget about your notes.
