To make it a bit easier for non-techies to modify your keyboard shortcuts, I’ve put all the currently useable keyboard shortcuts into a form that you can load into your config.edn file. You can copy the code below into directly into the file, above the :commands block, for instance.
;; These represent the default key bindings for Windows and Linux
;; (MacOS binding shown to the right, where different.)
;; MacOS: `mod` = `command`
;; Windows/Linux: `mod` = `control`
;; To change key bindings, uncomment the line (delete the `;;`)
;; and put your new key bindings in quotes after the command name
;; Check [this](https://craig.is/killing/mice#api.bind)
;; for the specific bind syntaxes that mousetrap support.
;; Copy and paste the :shortcuts block into your config.edn file
:shortcuts {
;; ;; These are shortcuts when not in edit mode
;; ;; Type the keys one after another
;; :editor/toggle-document-mode "t d"
;; :ui/toggle-theme "t t"
;; :ui/toggle-right-sidebar "t r"
;; :ui/toggle-new-block "t e"
;; :ui/toggle-between-page-and-file "s"
;; ;; These cannot be changed
;; ;; "tab" (-> (editor-handler/on-tab :right)
;; ;; enable-when-not-editing-mode!)
;; ;; "shift+tab" (-> (editor-handler/on-tab :left)
;; :editor/undo "mod+z"
;; :editor/redo "mod+y"
;; ;; :editor/redo "mod+shift+z"
;; :go/search "mod+u"
;; :go/journals "alt+j" ;; (if util/mac? "mod+j" "alt+j")
;; :editor/zoom-in "alt+right" ;; (if util/mac? "mod+." "alt+right")
;; :editor/zoom-out "alt+right" ;; (if util/mac? "mod+," "alt+left")
;; :editor/cycle-todo "mod+enter"
;; :editor/expand-block-children "mod+down"
;; :editor/collapse-block-children "mod+up"
;; :editor/follow-link "mod+o"
;; :editor/open-link-in-sidebar "mod+shift+o"
;; :editor/bold "mod+b"
;; :editor/italics "mod+i"
;; :editor/highlight "mod+h"
;; :editor/insert-link "mod+k"
;; :editor/select-all-blocks "mod+shift+a"
;; :editor/move-block-up "alt+shift+up" ;; (if util/mac? "mod+shift+up" "alt+shift+up")
;; :editor/move-block-down "alt+shift+down" ;; (if util/mac? "mod+shift+down" "alt+shift+down")
;; :editor/save "mod+s"
;; :editor/next "down"
;; :editor/prev "up"
;; :search/re-index "mod+c mod+s"
;; :graph/re-index "mod+c mod+r"
;; :ui/toggle-brackets "mod+c mod+b"
It might also be useful in the future to have a separate keyboard-shortcuts.edn or similar, alongside the config.edn file instead of as part of it. Keyboard shortcuts are something most users are going to share verbatim across multiple repos, while config.edn is likely to have repo-specific settings.
thanks a lot for this, It’s a great reference point, this method I’d still say is not very user friendly for no-techies like @IcedAndCorrected said. Of course this post is super helpful for anyone who still wants to experiement with this.
I agree, this would be a lot cleaner, it’d be of course amazing to eventually have a simple GUI for non-techies.
With that said I’ll start customizing shortcuts straight away!! thanks again @IcedAndCorrected
Agreed, still not a long-term solution for non-techies, but definitely easier than trying to pull the relevant details out of the clojure code themselves
I had to do it for myself anyway and figured others would benefit, so I’m glad it helped.
I kept those in there just for my own reference, based on how I copied and transformed the keyboards.cljs file.
Currently, the actual app code doesn’t allow these to be customized. I don’t think it would be too hard for the devs to add, but I’m not familar enough the codebase to know if there’s some reason those weren’t made to be customizable.
Ah, that’s just some clojure code in the original I left in to show what the default mac key binds are.
As the code works currently, it checks to see whether you’ve set a key bind for given command in config.edn. If you do, it uses that. If you don’t have a key bind set, it chooses the default key binding based on whether you’re on a mac or anything else. As of now, if you set a key bind in config.edn, it will be the same on all platforms.
I’m in the same boat (I use macos and linux). Out of curiosity, does left_alt + j work on Mac if you use that key bind (without the (if util/mac part)?
I have been thinking about the best way to solve it. I don’t want to burden the dev team as they’re working on more important core features. The easiest solution would be to run the util/mac? check when the app reads the config.edn, and replaces alt with mod in any string, but that won’t be as flexible and could cause unexpected conflicts (e.g. you have mod+j and alt+j both mapped to something.)
I’m working on learning clojure and hope to be comfortable enough in it in the next week or so that I can start contributing PRs.
Got you, yeah I don’t know any clojure so I’m a bit lost with the if util/mac and why mac doesn’t work with the linux set-up (which I assumes also works in windows)
In my case alt doesn’t seem to work for me, not even if I do left_alt + j
and yeah with the example I put, I was only doing mod+j and alt+j for testing, I only need alt+j since unmmaped that one from daily journal.
I thought there might be some requierment to do "mod+j" "alt+j" for alt+j to work.
Good to hear I got a fellow Linux / mac user who struggles with mac’s stupid keys as well If you do figure out more about this please let me know in this post, I’ll keep an eye on it.
