Keymap settings not registering enter key
Hi,
While trying to swap the new block and new line shortcuts on the keymap settings, I’ve encountered a problem : it won’t let me reassign the key to any command, nor <shift+enter>, while <ctrl+enter> is registering. the reset to default option is not working as well…
how can I register and <shift+enter> ? Or at least restore the default settings ?
Welcome. Go to file config.edn and check section :shortcuts . The default configuration is this:
 :shortcuts {}
Hi, thank you for answering me ! I did do that in the end which is an effective workaround. So your answer is a solution, but the keymap settings are still broken which is unfortunate :frowning:
