Is it possible to populate a block with the content of the parent block using kits? For example
- [[Parent Block Title]]
- TODO Some task #someone needs to do
agency-name:: {{parentref}}
Yes:
config.edn , inside macros{} ::pp "<span class='kit' data-kit='parentprop' data-prop='$1'>$1:: parent</span>"
pp with a name of your preference.ParentProp in Logseq, put the following code in a javascript code-block:logseq.kits.setStatic(function parentprop(span){
if (span.closest('.ls-block:has(a[data-ref=template])')) return
const blockId = span.closest(".ls-block").getAttribute("blockId")
const block = logseq.api.get_block(blockId)
const content = block.content
const macroName = span.closest(".macro").dataset.macroName
const macroStart = content.indexOf("{{" + macroName)
const macroEnd = content.indexOf("}}", macroStart) + 2
const prop = span.dataset.prop
const text = logseq.api.get_block(block.parent.id).content
const replace = (prop === '$1' ? text : '')
const newContent = content.slice(0, macroStart) + replace + content.slice(macroEnd)
logseq.api.update_block(blockId, newContent.replace('{{' + macroName + '}}', ''))
if (!replace) logseq.api.upsert_block_property(blockId, prop, text)
propname:: of a block:
propname:: {{pp}}{{pp propname}}{{pp}}
{{pp}} at the end of the block.You are absolutely awesome! Thanks.
I tried on my own but didn’t have any luck. Can I have a version of the function that only gives me the contents of the parent block? May I also have the corresponding config.edn entry? I tried just making a copying your function and giving it a different name but calling it gave no output.
I’m not sure of what you expect. Please be more specific. Maybe describe the steps that you made, so as to find the misunderstanding.
Thanks for responding. Your current script takes one argument and provides an output like this: $1:: [[parent block]] (example, agency:: [[ENAGB]]). I would like a version that just gives me the parent block content by itself with no argument. For example,
- [[Parent Block Content]]
-{{pq}}
will give me
-[[Parent Block Content]]
My plan is to use this function to dynamically provide the value for block/name in an advanced query based on the value of the parent block. That way, I can query all the tasks and linked tasks for that page. For example
- [[ENAGBE]]
- #+BEGIN_QUERY
{:title [:h3 "Tasks with page reference"]
[?p :block/name "{{pq}}"]
[?b :block/refs ?p]
[?b :block/marker "TODO"]]}
I have updated the code to support your scenario with the same macro. Read the additional instructions at the end.
Hello again,
I tried this out today, because I want to try to auto-evaluate LaTex equasions using JavaScript, but it just seems to return
$1:: parent
or
macro-argument:: parent
I’ve tried all three versions of the code, I have it in my config.edn, I have the page you gave me, but somehow it just always returns parent no matter what I giveconfig.edn:
:macros {
ParentProp.md:
Test JavaScript.md
$$3*3$$
-```runjs
// Load Evaluatex.js dynamically
const script = document.createElement('script');
script.src = 'https://cdn.jsdelivr.net/npm/evaluatex@latest/dist/evaluatex.min.js';
document.head.appendChild(script);
script.onload = async () => {
try {
const latex = "3*3"
// Evaluate the LaTeX expression
const fn = evaluatex(latex);
const result = fn();
// Display the result in this block
setOutput(result);
} catch (err) {
setOutput('Error: ' + err.message);
- Test
- {{pp}}
Does the format of the macro section in config.edn matter? Does the formatting of the JavaScript matter? Does it not actually have a parent and I’m stupid?
Thanks in advance, all answers are welcome
Welcome.
ParentProp.md is placed inside a Javascript code-block.Ctrl + Shift + i).
